hi i have a n73 on 3 with v3 firmware
i want to change it i an in uk
is this the best product code to use 0529825 then you can upgrade to Version: 4.0726.2.0.1 ?????
i have had a look around and found this http://www.allaboutsymbian.com/forum//forum/thread/53110/
is it the same for n73??????
and a carnt download this app gsm-magic
http://rapidshare.com/files/1236869/Copie_de_gsm-magic.rar.html
as it not there any more
and dose this fix the maplag with tomtom
thanks spurry05
I'm a UK user on Orange and I used 0527009 and all is well. This is a generic "vanilla" code and will remove all 3 branding. Be wary of this as 3 often supply unique apps with their phones. I previously had a vanilla ME version without any problems.
To change the product code, you will need a piece of software called Nemesis Service Suite. I'm sorry, but I don't have a link to this.
Once changed, use Nokia's own app, NSU, to perform the upgrade.
Not sure if this version fixes the TTN6 Map lag as I never experienced it before hand, and haven't had the chance to try TTN6 out since updating the FW. I believe those that experience this believe it is more to do with the TTN6 coding, rather than the N73 or it's firmware.
Just a word of warning...
When upgrading, make sure not to disconnect or interrupt the process in anyway. Make sure your USB cable is firmly connected and that the phone has a full battery or is connected to the charger. If the upgrade process gets interrupted in anyway, you will have an expensive paper weight on your hands.
Good luck 😊
thanks i will give it some thort
spurry
thanks done it but it did not fix the map lag with tomtom
so i wanted to no can i put it back to how it was with all the 3 thing on it
thanks again spurry
spurry05 wrote:thanks done it but it did not fix the map lag with tomtomso i wanted to no can i put it back to how it was with all the 3 thing on it
thanks again spurry
hiya mate try disabling a few points of intrest in tomtom 6 i had slow down in it checked the pois and every 1 was enabled selected the 1s that are vital and it works a treat.
as for downgrading to old firware you wont be able to do it via nokia update it will just say
newest software installed
a good flasher could solve it for you or a nokia service centre but the new firmware is pretty good and seems quite stable to me
kinda miss my music key but ive just changed top right soft key to music player 😊 music player is still upgraded version and still starts with phone so thats cool 😊 and allthough i miss the music key i kinda like having that other shortcut it is soooo handy 😊
Long press the Music key - should open music player.
