the link on n9210.co.uk doesnt work 😞 please email it to me if you have it [email protected]
can someone hook me up with RealProducer Basic
Real have replaced this product with Helix Basic. As yet I haven't tried it so see if it will create RM files for the 9210. Send me an e-mail and I'll see if I can find the proper version of the free Producer Basic.
Regards
I downloaded Helix Basic. Unfortunately it won't let you resize, change the bitrate, codec etc. as per the settings they recommended on their page. so that you can output an .rm file that will play on the 9210 😞 any suggestions?
forget about stupid RM go for NIM 😛 😉
You can convert rm to avi with TMPGenc. (and than from avi to nim)
[quote="Dazler"]forget about stupid RM go for NIM 😛 😉
You can convert rm to avi with TMPGenc. (and than from avi to nim)[/quote]
I would love to but I simply cannot get ANY version of MMC to work on my laptop no matter HOW much I tweak it and change settings here and there. It keeps crashing the second it begins to encode. I'm using XP and I know there are issues regarding this but I'm at a loss. 😞
bah yes, stupid buggy software :s
I've seen people saying this before, the common answer was that this was due to the P4 and XP :s
I have XP and my multimediaconverter works out fine... hmm...
anywyz Dazler, how's the tutorial coming? 😃
It's huge, think I'll slim it down a bit 😃 It started to be a custumization tutorial instead of a skinning tutorial 😃
But It's comming ... almost done
