New sync software.
23 replies · 5,768 views · Started 13 January 2003
Does anyone know a place where one could upload stuff for the P800?? I got a hold of the sync software v.1.0.0.4 wich is much more stable then the one included on the cd. Althogh I herd that SE have v. 1.0.0.7 out but I havn't found it yet.
pnyxter: what is the file size? Think you could e-mail it to me and i'll upload to my temporary web server.
SE seams to have some strange way of naming there files. I have the 1.0.4.0 software but the file I recived from SE says 1.0.0.4 so I guess someone had a bad day when naming the files... Sorry...
The rar file with the new sync version is 51 mb. So I can't mail it...
someone created a Yahoo folder for SE sync software
http//groups.yahoo.com/group/P800_software/
maybe that is where to post it.
I've asked SE for an official permision to distribute it until they put it online - but so far no answer - and I dont want to bet high on the possibility....
where can I download this latest sync software.
Please. I am desperate.
My P800 has been replaced twice already and I had to install and manually copy all my contacts and recreate my tasks, etc twice already.
I can't get the 1.0.2.0 to owrk ever since.
I would really appreciate the help.
I just added a P800 portal page at pdaPhoneHome.com and I'm working on an FAQ. It is user fed, so please submit any FAQs you have. The link directly to the download section is HERE. You will just need to zip it. If you have any problems, let me know.
The problem still is that even though I rar'd the PC-Suite it is 51 Mb and I can't put it on Yahoo since it's to large....
pnyxter,
That's a big file! Is it OK to post for downloading.... licensed? If so, I could try to get it up there... Send me a message.
can someone please send it to me via MSN messenger?
I really need this today as I have lots of apps, contacts, etc.
I will be online the whole day...
My msn messenger handle is rtsport
email [email protected]
Thanks.
hi
can you please give me the email address of the SE you were contacting?
I have emailed different SE offices in diff countries but they do not respond.
Thanks.
Has anyone had any luck uploading the new sync software?
I've not been able to sync my P800 with my PC (my software is ver 1.0.2.0). So I hope that the new software will solve my problems.
Thanks.
At least I have the new PC Suite CD. I got it from the Sony Ericsson here in the Philippines.
It has a confusing version. When you install it, you would see a version 1.0.6. But when you right-click on the P800 icon on the system tray (near the clock of your PC's desktop) and select the Phone monitor's About menu, it would be listed at 1.10. Anyway, backup/restore is version 1.4.2.0.
I think this would solve the synch issues for other people... I recommend that you get this version.
Hi Spoon!
Would it be possible for you (or anyone else) to upload the new PC Suite to pdaPhoneHome's website? I really need to sync my P800! 😞
Thanks.[/b]
Hi there!
Sony Ericsson just posted a new version of the PC Suite in their site.
Here is the direct link:
http://www.sonyericsson.com/downloads/PCSuiteForP800_rel_1.1.1_EN.exe?traceClick=yes
ENJOY! 😃
I put this link in the downloads section of pdaPhoneHome....
The link, however is just for this file. Do you have the url for the page that preceeded this. I have not been able to find it on the sony ericsson site... you need to pick the right country to get to that page. Because the link will only work for this version of the Suite, I'd like to offer the url that got you there.... for future reference.
Thanks.
Sorry for not replying to any of the messages I got. I've been tied up with another project and haven't had time to read the forum for awhile.
SE have posted the 1.1.1 sync version on their site so no need for me to upload any more.
http://www.sonyericsson.com/spg.jsp?page=gsapopup&Redir=template%3DSP1_17%26B%3Die%26PID%3D9940%26LM%3DSD_V%26start%3D0
got this form the readme.txt
(37.8 MB approx. 93 minutes on a 56k modem)
Executable File (EXE)
License: Free
Operating system: Windows 2000� Windows ME� Windows XP
Compatible with: P800
Pre-requisities
-Deskstand, Infrared or Bluetooth
-MS Outlook/Lotus Notes/Lotus Organizer
-Windows 2000 Service Pack 2/XP/ME
System Requirements:
-At least 100 MB free hard disk space.
-Windows 2000 with Service Pack 2: 64 MB RAM, 266 MHz
-Windows ME: 64 MB RAM, 200 MHz
-Windows XP: 128 MB RAM, 300 MHz
Install instructions
1. Download the installation package to your computer (remember
where you place the downloaded installation package file).
2. Close all processes (when installing the Sync Station
component make sure your email application is closed).
3. Double click on the downloaded .exe installation package
file.
4. Follow the installation instructions.
5. Reboot your computer after installation.
How to use
Connect the phone via Deskstand/IR/Bluetooth.
Start synchronization either from the icon in the system tray or
from the Start menu: Start/Programs/Sony Ericsson/P800/Synchronize.
For further instructions please use the Getting Started Guide or
the User Guide.
The PC Suite for P800 includes the following free software
applications:
Sync Station allows you to synchronize content such as contacts,
calendar and tasks, between your phone and your computer.
Backup and Restore allows you to save information from your
phone to your computer. If you have lost information in your phone, you can
easily restore the data from a saved backup on your computer or from another
phone.
File Manager allows you to convert your file types, rename or
replace both individual files and entire folders.
Install Software allows you to download and install software on
your phone.
Download Language allows you to download languages to your
phone.
Phone Connection Monitor allows you to check the current
communication status and provides shortcuts to many of the settings for your
phone. After installation, the Phone Connection Monitor will start
automatically every time the computer is started.
Dial-Up Networking Wizard will guide you through the creation of
GPRS or HSCSD dial-up connections for your personal computer to connect to
the Internet or to a corporate network.
The Mobile Phone Monitor Control Panel applet allows you to view
and update mobile phones connected to your computer, COM ports on your
computer and SIM cards recognized by your computer.
Modem drivers for Sony Ericsson P800 mobile phone.
Notes
Release 1.1.1 of the PC Suite for P800 (identical to P800 CD1
1.1.0) is intended as an upgrade from release 1.0.0.
After an upgrade from 1.0.0 the synchronization may not work at
once. If the error message 'Folder/section cannot be opened' is shown use
the following solution:
1. Start the sync settings dialog from system tray or from Start
menu: Start/Programs/Sony Ericsson/P800/Sync Settings.
2. Verify that the settings are correct and press OK.
This will update the sync database and make it possible to sync
with the new version.
