E65 - explanation wanted for a screen icon
2 replies · 2,218 views · Started 09 July 2007
Can anyone help me identify a screen icon on my E65? It's an arrow pointing upwards above a shallow sided 'tray' and it sits just below the battery indicator. My instruction manual doesn't have an explanatory list of icons and the manual I downloaded, while it has such a list, it doesn't include this one!
mmm - message in your outbox I think ... it might have failed, and is just sitting there ... !
Thanks! That's exactly what it is! My problem is that if I set up my email accounts to use WiFi then the outgoing mail server won't work with GPRS/3G and vice versa so stuff tends to get stuck there.
