The file manager and gallery folders will not open. When I select either one, the progress bar shows but seems to hang up. All other folders open ok.
Can anyone please advise me how to rectify this.
Thank you
Dglad
Thank you
Dglad
Memory card gone bad? If you remove it, does it work then? If not, then this will help clear the issue (and your data):
http://www.allaboutsymbian.com/forum//forum/thread/17507/
Thank you for the reply, I removed the memory card and this cleared the problem.
I formatted the memory card, reinstalled TomTom and now all is ok.
Many thanks
Dglad.
