I have a Nokia N73 which is locked with T-Mobile(U.K)!!
Can anyone help me???:con?
Hiya Mate
You Could Allways Try This
Buy Cheap T Mobile Sim Card
Top It Up 20 Quid And Register It In Your Name And Adresse
Ring T Mobile Customer Services Tell Them Youre Going Abroad For A While And Wish To Use The Handset With A Foriegn Sim As To Avoid Roaming Costs Etc
They Should Be Able To Help You
By Law Uk Pay And Go Handsets Have To Be Unlocked If Asked Allthough They Usaully Charge You Still With Pay And Go You Are Paying For The Handset With Contract They Can Refuse As You Got It Free With The Contract Or Part Of The Contract But With Pay And Go You Are Paying For The Handset Itself
Hope That Helps Mate
Ps It Can Take Them Up To 4 Weeks To Send They Seem To Love To Drag It On And On
Also
You Should Make Sure That No1 Has Tryed Entering Codes Into It Before As You Only Get 3 Chances To Do It By Code Then It Has To Be Done By Other Methods
Nice1 Good Luck
Thanx for d info but the problem is im in INDIA now & the Phone is with me......
sajidwhosane wrote:I have a Nokia N73 which is locked with T-Mobile(U.K)!!Can anyone help me???:con?
You can unlock your mobile using unlock code...you can get the unlock code here http://www.mobile-unlocker.com/unlock-your-phone/rs2wp2/ It provides unlock code and instructions...By using this you can unlock your mobile easily...
You can unlock your mobile using the http://www.mobileunlockguide.com/ .This site provides the unlocking instructions for your mobile..Once you get the code, you may follow the instructions from the above site..
