Remove Ap. E70
3 replies · 1,583 views · Started 10 July 2007
I've got an ap. (sisx install file) on my E70 that I want to remove. The ap. is not installed - it's just the sisx file. The manual says I should go into the ap manager, Options -> Remove, but I have no Remove item on the Options menu. I have not been able to locate the sisx file through PC Suite.
Go to tools, application manager, find the application that you want to remove. Select it ,then from options remove it. Worked for me before. hope it helps
Here's the twist. I just checked, and I have the "Remove" item on the options menu for every other application; whether installed or not - sometimes in different locations on the Options menu (might be related to whether it's installed or not).
But when I go to the specific ap that I want to remove, Options does not have Remove on the menu.
As often happens, discussion helped. After I responded, I decided to see what would happen if I installed the ap. After installation, Remove showed up on the Options menu. No problem. Thanx.
