Hi everyone,
I am a new member, and from short time I have a Nokia N80 Internet Edition.
I have one interesting question:
It is possible to remove/hide/ ShortCuts of programs in "Smart menu",
and for example if is necessary, they will be started from File menagers or Task menagers.
That means that program can work in background or not work, just start from one of before described ways
This is possible in Windows CE!
Thanks for HELP!
smart menu???
Is that active standby on the front screen??
or is it the 'Go to' menu???
This is a button who activate Menu of Symbian!
The button is of Front side of N80
And when button is pressed for longer time, he activate Standby...
Oh, the menu button when held down only shows you the programs you have still running in the background. Its not a list that is static... i.e. it will change depending on what you have had open and NOT closed before going back to start screen...
For example... if you go to contact, call a contact and use RED to end the call you will be back at start screen.
Hold down the menu button and you will see Contact and standby. You can then click 'C' on the Contacts to close or select it to go back to contacts...
Its not a configurable menu.
I now all described....
I need way to hide programs from Start menu........ Symbian 9.1v3
I dont think you can hide from the main menu.
You can move from folders like 'My Own' to other folders using Options and move to folder, but you cant move the ones on the main menu
I think that the problem is in Symbian Version.
System Files are locked ore...
if any ideas please write...For me this is very importance!
Please any ideas or opinions?
