Australia n95?? this is form a total newbie, go easy....pls
4 replies · 2,573 views · Started 10 July 2007
ok, so i am planning to get myself a N95, but i've found out that in Australia, it doesn't have Chinese. and from reading this forum, it seems that it is possible to change the product code or something and the phone will have another language installed? i only wanted chinese so that i can send and receive sms back to Hong Kong, and mainland china. if it's possible, would anyone kindly show me how? thanks alot!
ps: i've searched for it, but there are waaay too many threads, sorry if it's been covered.
chocoloby wrote:ok, so i am planning to get myself a N95, but i've found out that in Australia, it doesn't have Chinese. and from reading this forum, it seems that it is possible to change the product code or something and the phone will have another language installed? i only wanted chinese so that i can send and receive sms back to Hong Kong, and mainland china. if it's possible, would anyone kindly show me how? thanks alot!
My Youtube video with all the links .. download the software etc .. instead of using Euro 1 pick one of these codes (I can't vouch whether the latest 12.0.0.13 is available yet but at least you'll end up with chinese text/menuing and input support)
http://www.youtube.com/watch?v=uN9eRlddfH0
#0534832: Hong Kong
#0536084: Hong Kong
#0534830: Taiwan
#0536083: Taiwan
Good Luck!😊
wow! awesome! thanks for that, even tho it's a bit blurry, but i'll get my way through once i get the phone!
cheers!
I'm pretty sure the product code for Singapore will include Chinese input as well since 70% of Singaporean are Chinese.
Yeah.. it does - but the Singaporean code will only have Simplified Chinese (which is what they use) and not dual Simplified/traditional Chinese (that is the norm in Hong Kong and Taiwan).
