Is there any way you can create a sub folder inside one of the main ones. I can do it on the menu screen but not lets says in the images folder.
Also is there any way of locking a folder with a pass code
Cheers
Cheers
I think there is a program available, there definitely was one for previous nokia's. Will have a look for you tomorrow when im more awake.
wethery wrote:Is there any way you can create a sub folder inside one of the main ones. I can do it on the menu screen but not lets says in the images folder.Also is there any way of locking a folder with a pass code
Cheers
Im using 'Advanced Device Locks for Nokia S60 3rd edition' pretty good does the job. It costs about $11 from Handango.
