Can someone give a bit advice please. Im trying to use the wi-fi on my phone. Ive just been to my sisters and the pages were loading fantastic,quick as anything. As soon as i come home its crap yet it has a full signal. I know it could be the router but my wireless computer is fine
Any advice please
Maybe your router is set to 11 Mbps instead of 54.
ratza wrote:Maybe your router is set to 11 Mbps instead of 54.
Ive checked that, i moved my cursor over the icon in the bottom of the screen and it says 54
Signal strength is not necessarily an indication of speed.
It sounds like an access issue cos the phone sets you automatically.
Go into the WiFi wizard and setup again.
Call your routers IP address and see if you can access the admin control panel.
Check all settings and reboot!
Good luck.
