After installing the latest firmware v12 today on my Nokia N95 i noticed a big problem with the camera. When using the camera in slightly low light i can see a lot of lines across the screen and these lines are constantly flickering affecting the picture quality quite badly. I have only noticed this problem after installing the latest v12 firmware, i definately did not have this problem before. Has anyone else experienced this problem after installing the latest firmware on their Nokia N95?
Big problem with Nokia N95 camera after V12 firmware update!
I'm getting the lines as well but it doesn't seem to affect the quality of the photo when it's taken.
the flickering horizontal lines affect the video quality more in low light because they can be seen when you playback the video. it is really a bad problem hopefully nokia will quickly fix this with a new firmware update. the camera was fine with the previous firmware and now it's quite bad with the latest firmware. i can't believe more peole haven't noticed this issue.
Because I only had V11 for a brief period I didn't notice this but now on V12 during Light Amplification ( Night Mode ) on both photo mode and Video my frame rate drops considerably and its simply a pain to use the camera in this mode its almost unusable in Video mode it might as well be disabled. I dot notice flickering lines but I wouldn't mind this fps drop to be fixed.
I am having the same problem seeing lines during photos in low light...The camera has turned into a horrible quality camera after v12 firmware update. I hope Nokia fixes this problem quickly
Hey, i updated my nokia n95 from firmware 12 to 31. After that camera doesn't work...??? What can i do...
Is there any possibility to get my last firmware version or install a another version????
Plz do reply <[email protected]>
daz25 wrote:After installing the latest firmware v12 today on my Nokia N95 i noticed a big problem with the camera. When using the camera in slightly low light i can see a lot of lines across the screen and these lines are constantly flickering affecting the picture quality quite badly. I have only noticed this problem after installing the latest v12 firmware, i definately did not have this problem before. Has anyone else experienced this problem after installing the latest firmware on their Nokia N95?
Which network are you on? V12 firmware is VERY old. The latest is V31.
