N75 Personalization Help!
1 replies · 1,762 views · Started 11 July 2007
On the main screen, the screen that pops up after you flip open the phone, you have the 3G and clock at the top left corner of the screen. Directly to the right of the clock is the "name". This "name" is usually AT&T or Cingular. My question is; how do you change the name! I've gone through all the settings, yet still can't change the name!
Much help needed!
Thanks,
Sretsnom.
That's the network operator name. You cant change that in any of the settings. If you unlocked the phone and put in a T-Mobile sim, it will say T-Mobile.
The only way to change it would be to get $100 Billion dollars and buy at&t.
Then you can change the name to whatever you want.
