Hi all, I just bought my P990i. I noticed that there is a TRYBUY folder in the memory card. Its consuming like 23MB of precious space.
Its in File Manager/Memory Card/Document/TRYBUY
Does anyone have this on their phone? Is it ok if I erase this? I dont think that the freeware (for 30 days) is important anyway.
No problems deleting it. If in doubt, or if you think you might want to try some of the software in the future, just make a backup copy.
Adam
Thanks for the reply.
Just found out why the file is so big. These are installers! But as far as I know, these are only good for 30 days after you install them and then you wont be able to use em not unless you actually buy the software...
