I'm in the market for an N95 and I was wondering if I could do voip over the my data plan (edge for us market in particular). How's your experience with it? To push things even further, can you do video chats using wlan or edge?
VOIP over EDGE (or 3G)
Truphone allows you to do VoIP over 3G.
neilhoskins wrote:Truphone allows you to do VoIP over 3G.
I have truephone installed. so that means i can do video calls via my truphone number and not get charged by orange.
no, it means that you can use voip over the 3g network, but it will not give you any video. you'll be charged by orange data plan.
basically it's just using the 3g instead of wifi. you need truphone v3.
Fring also allow that.
satello wrote:no, it means that you can use voip over the 3g network, but it will not give you any video. you'll be charged by orange data plan.basically it's just using the 3g instead of wifi. you need truphone v3.
I only use truphone in the house so i can not get charged a pennny by getting the link from my WLAN
