Changing the fascia ain't so simple after all...
3 replies · 3,021 views · Started 12 July 2007
I got a Black N95 fascia off eBay (yes I know:icon13: ) but wanted to try it out and see what it looked like, how it fitted...
Got the front on okish, but it still seems to have a tiny gap all along the right hand side when the slider is up, not good, but can live with it.
As for the back, oh dear, I think I screwed things up some what!
The buttons are quite hard to take off and now don't actually click into place in the new fascia, I had to sort of put them in place and put the fascia on all in one go, they still click (camera, gallery, zoom)
It does look ok and I think it might just be down to the poor quality of the case.
But the major issue is that after I put it on, when I make a call I can't hear it ring, I have to put it on loudspeaker for it to work, ooops!
Anyway just thought I might let people know if they were thinking of doing the same.😊
afaik top speaker at the up part and his contacts at the bottom part. so i guess contact
broken while assembling screen slider.
Jon_8986 wrote:I got a Black N95 fascia off eBay (yes I know:icon13: ) but wanted to try it out and see what it looked like, how it fitted...
iv changed the back on my n95 with no probs, also iv taken the front off just to have a look, no probs here at all with sound etc, try putting ur original parts back on and see if it fixes the prob, cant see it helping but........
