Copying SD Card Contents
1 replies · 1,755 views · Started 13 July 2007
I have a new (faster) memory card and want to copy all the files from my old one to the new one so that i can just replace them with everything still working!
Is this easy to do - can i just copy them over via a PC?
lj2007 wrote:Hi,
Yes!
Create a folder on your PC and copy into it all folders from the old mem card. You should remember to unhide hidden folders/files first.
Copy all folders onto the new card and then insert it into the phone.
Uninstall all apps from the phone and then reinstall all apps to the phone. This will clean up the phone's file allocation table and everything will run faster.
