Backup contacts in a readable file
1 replies · 4,359 views · Started 13 July 2007
Hi all. I have a serious problem: i need to transfer my 5500 contacts into an other phone, but i can't use the SIM 'cause it's so old and small that it would truncate all my strings.
How can i backup 5500 contacts in a readable format, like CSV?
scitrek wrote:Hi all. I have a serious problem: i need to transfer my 5500 contacts into an other phone, but i can't use the SIM 'cause it's so old and small that it would truncate all my strings.
Choose select all and select all of your conracts, then choose "copy to Memory Card" from the same menu; they will be recorded at your memorycard in the "others" directory as ".vcf" files ...
