N73 wont Boot
4 replies · 5,299 views · Started 13 July 2007
chaman_chindi wrote:the phone just does not booot......it happens randomly after i remove the battery n try to switch on,......any views
hiya mate
any chance the phone has got wet??
how loose is the battery when you insert it??
as it happends randomly it suggests maybe loose connections dont touch them but are the battery terminals in good condition on the phone and the battery itself??
is the phone under warranty??
nokia service centres can be very helpfull and free if they are under warranty still you can find your nearest store with this link
http://www.apps.nokia.co.uk/clubnokiaservice/
just type in your postcode and slect service center at the top and away you go 😊
hope that helps a bit
i would suggest a firmware update to see if that helps at all but if the phone is unstable and could reboot i wouldnt recomned this as the update can take 20 mins and if the phone becomes disconnected you have a heavy brick on your hands
its under warranty but ,,,i am sure it cant b the battery problem as it starts to load with NOKIA label n then hangs,,,,its geting the powar from the battery...n also my n73 randomly hangs while in operation at any given moment ......is this common here..
chaman_chindi wrote:its under warranty but ,,,i am sure it cant b the battery problem as it starts to load with NOKIA label n then hangs,,,,its geting the powar from the battery...n also my n73 randomly hangs while in operation at any given moment ......is this common here..
my n73 has crashed afew times but only with alot of things open hardly does this with the new firmware out . maybe this firmware has better ram managment
have you had the phone from new?? or is it 2nd hand?? has it allways done this??
