What is the deal with dataviz pocketsync for the Z8 will the p990 version not work.
How about the java version is this possible?
Tim
Tim
so to answer my own questions
1. roadsync (exchange activesync) from the SE site doesn't work, it installs all looks hunky dory then when you run it pops up not supported.
2. the java midp works, but only does inbox, no calendar or contacts.
Can you explain the Java midp part?
Calendar I want to sync with my work PC, so using PC Suite on demand is fine, but my inbox I want with my personal mailbox.
if you go to the dataviz site there is a java version that you can use. Just look under the download section.
Tim
