I just read this in one other thread.
kontraband wrote:For example... if you go to contact, call a contact and use RED to end the call you will be back at start screen.Hold down the menu button and you will see Contact and standby. You can then click 'C' on the Contacts to close or select it to go back to contacts...
So I have a quick question. Very very often I forget to check the background running applications. Especially after I finish my calls I forget to close the "contacts". And since we all know that the battery is "draining" from those applications running in behind, I wanted to ask if there is some kind of automatic closing of those applications?
Thank you
