The P990's R6D23 update.... in depth
2 replies · 2,100 views · Started 14 July 2007
AAS regular and committed P-series fan Asri al-Baker takes Sony Ericsson's latest R6D23 firmware update to task, although he admits at the end of the day that it's still a worthwhile step, thankfully with less new bugs than fixes for old ones.
Thank you for the information. May I ask what theme you are using, it looks very clean. Also, what are all the green indicators at the bottom right for?
Unregistered wrote:Thank you for the information. May I ask what theme you are using, it looks very clean. Also, what are all the green indicators at the bottom right for?
I use PURE theme, which is one of the default theme in Motorola RiZR Z8. The green indicators are part of an excellent application called Swiss Manager Pro.
Asri al-Baker
