Windows Live Messenger - Not sync'ing contacts
1 replies · 2,286 views · Started 14 July 2007
Hi folks,
INstalled WLM a few weeks ago and tried to import my contacts but although I can see them all appearing when I do this along with the "Please wait...", then it says "there was a problem, please try again" and the contact list is completetly blank.
Anyone else run into this trouble and found a work around?
Many thanks,
Rikki
Uninstall it and try it this, when you go to install the application again make sure you install DEP FIRST! Then windowsLive-S60.
Hope this helps.
