Firmware On 3230
4 replies · 4,689 views · Started 15 July 2007
advut wrote:How To Flash New Firmware In 3230 Via Datacble At Home... ..
It can be made if you have the firmware files and Phoenix Service software. I won't recommend though.
It may be possible to flash it at home ...just not so sure. Try the nokia pc suite, click on last icon. U will need a reliably fast broadband to do it just enter the code written on the phone, when asked and if ur phone is supported, u may proceed further as per the instructions...thats it...
The 3230 does not support PC Suite/Nokia Software Updater firmware updating.
With the 3230 you need relatively expensive flashing equipment and illegally distributed firmware files, or the help of a Nokia repair center.
