Wallpaper Problem on Full screen
12 replies · 25,918 views · Started 15 July 2007
Hi
I have N70 and i am not able to set a wallpaper on the full screen.
I tried editing the image to the screen resolution of 178x208 pixels still the image comes below the operator logo and the indicators clock and operator logo still appears and the whole screen looks messy.
Can any one tell me how can i set an image as a wallpaper on the complete screen??
your help would be really appreciated.
Thanks in advance.
I'd like to be able to do it too. I have seen fullscreen wp on a n70me, but dont know if it was f/w or addon sw.
You can't. The only possible way is to create a theme using the image, but it isn't so easy.
hai friend iam also having the n70 iam also having the same problem like u so ifd u get any solution for this problem please help me
so plese help me friend
nani07079 wrote:hai friend iam also having the n70 iam also having the same problem like u so ifd u get any solution for this problem please help me
To have fullscreen image, it should be part of theme!
Just use photoriteSP, a camera software for n70 with image explorer support. Through it's image explorer u can select any image to fit the area of the screen from it's options menu.
mkstalal wrote:Just use photoriteSP, a camera software for n70 with image explorer support. Through it's image explorer u can select any image to fit the area of the screen from it's options menu.
thanks for new useful knowledge
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Symbian OS; Nokia N70/2.0617.1.0.3; 9424) Opera 8.65 [en])
you cant make it. Except u make a theme using the desired wallpaper. Regards
enteens wrote:Here is the way
download the file and read the steps
have you try that?
it tell that convert desired picture to mbm file then replace the existing file in E:\system\skins\theme-name
but i see the original mbm file has many component - clock, indicator, etc.
not only background picture
afraid that this solution will not work moreover create problem
if it work that would be good - theme studio and install many theme is a boring task
only need to change background (full screen wallpaper) frequently
mkstalal wrote:Yes it is possible to set full screen wallpaper without any theme
is it full screeen like this?
find info in website, there is no features about fullscreen wallpaper
whiskynine wrote:is it full screeen like this?
Hi, I have N70 & I installed PhotoRite SP 5.3.0 ,Borpwse the file and set as wallpaper but this program didn't work as u said!
It stretched th image not in fullscreen mode!!
Please help me how did u do this?
Thanks so much
