E50 - Unable to save msg in memory card
0 replies · 1,928 views · Started 15 July 2007
I am facing a strange problem with my new E50. Guess it runs with S60.
I bought a 2GB micro SD card, inserted the same and formatted.
I went to messages-> Options->Settings-> Other->Memory In Use
It shows two options
- Phone memory
- name of my memory card
However though I try to select the memory card as the memory to be used for saving the messages, it does not happen...radio button sticks tight at the phone memory.:con?
Has anyone faced the same issue?
Am I missing some steps???
Thanks in advance for any specific solution/fix...
Cheers
Atri
