For the loose slider I used this guide:
http://www.simplysymbian.com/2007/05/02/how-to-repair-wobbly-slider-nokia-n95/
Couple of tips & findings,
- when u remove the back cover, remember to start from the side with the buttons, same for when u putting it back on.
- To remove the black metal slider "guides" you will need a Torx 5 screwdriver. I cant stress enough, good tools makes the job easier... so make sure u got a decent torx screwdriver, and careful not to "eat away" at the screw heads, if you find the screwdriver is slipping, get another one... Not worth messing up the screw heads.
- My phone actually was loose on both sides, but I found that for the left side, I only had to take it apart and re-seat, tighten it up to make it feel solid.
- For the right side, I used electrical tape (the black stuff) and applied it as shown in the url above, but had to apply 2 layers to make it thick enough.
Also as one makes the whole slider system "tighter" one thing which will happen is that once you applied this "fix" the phone does become a little harder to slide open. But this is prob as I was used to having it too loose. It did feel strange for a little while, but I got used to it, and prefer it being slightly harder to slide open.
I actually had to do the "sticky tape" procedure 2-3 times to get it just right, but this is easy enough, only 3 screws, so just be prepared for a little trial and error.
Also note that this whole procedure is completely reversible.
Now totally unrelated, when I first got my phone, I found that the 4 screws that were holding the front sliding bit, the ones behind the screen. You see 2 screws by sliding up, and 2 by sliding down. These were loose, and I had to tighten them.
thats about it,
If you need more info just let me know,
And to "Lynchy", I feel your pain! just don't give up! hopefully they will get you a new one. Just keep hassling them... There is a great forum contributor in the N80 forum called "Cash", who has good knowledge about the legal "threats" that we as users can use, if things get hairy, I hope he wont mind me saying this 😉 but you can always drop him a PM to see what he can suggest.
good luck!
ut.
