Main Camera playing up
3 replies · 1,853 views · Started 16 July 2007
For some reason the main camera is playing up, when i open the lens cover i still see my theme background on the screen, also the icons seem to be staying down the side, then after a bit it says camera is in standby mode.
using the secondary camera isn't a prob.
please give me some advice, thank you..
Soft reset but that didn't make any difference. So checked on the net and could
see a few peeps have had probs with the main lens, crashing, double icons etc. and had adviced that if you tap above the lens it starts working.
I can get it to work with the tapping method, but has anybody had this prob rectified properly by nokia??
If so how do you go about getting them to do anything??
Can you just take into a nokia care centre?? Have you got to be a member of Nokia Club to get warranty work done??
Only i bought off E Bay, an unwanted upgrade so don't have the original reciept and don't know where i stand.
PLZ LMK..
