I would like to know if there's any way to rename a specific theme that is listed under tools > themes in a N95 phone?
How to rename themes
No built-in support for renaming themes. You can do it if you can get the original theme files and rebuilding the whole theme with the theme creation tool (Carbide.ui).
Just curious: Why do you want to rename a theme from whatever name the theme developer decided to give it originally?
it's actually a lame reason..like the theme name is dragon_x8929js and i want to download another theme which is dragon_fgiog1sa; it's basically for convenience switching back and forth on what theme I will use.... 😊
Good enough reason to me, if one switches themes often (and has a lot of them). I rarely install new themes, and I don't change them very often, either.
