N73 Memory Problem
4 replies · 2,883 views · Started 16 July 2007
The phone keeps saying memory full, delete some data...cant send texts or recieve them.
Looking at the Memory Details on the phone it says:
47mb in use
126kb free
8kb calender
39kb contacte
23kb messages
154kb images
582kb sound files
0kb video
So where is the suposid 47mb being taken up?! It seems like something is just using all the free sapce as it is freed up, i had 200 texts in the in box when it 1st happened, so i deleted them all....now i have 6 messages in there and its happening again :con?
Any ideas people?
Matt.C wrote:The phone keeps saying memory full, delete some data...cant send texts or recieve them.
47mb in use
126kb free
8kb calender
39kb contacte
23kb messages
154kb images
582kb sound files
0kb video
Any ideas people?
give a hard reset to ur phone....
procedure: 1.back up ur contacts and sms to ur pc via outlook express..
2.turn off ur phone..
3.then pressing these three buttons "*" /"3" /"green(call)" together turn on ur phone until the"FORMATTING" screen appears..
hope these will help u.
i believe its not referring to the internal memory, i think its more about the RAM. If you have too many applications running in the backround this will happen often. To check, hold down the menu key and the list of background application will show up. If you have applications that are running but dont really need them, you can end it by highlighting it and press the C button then OK. Mine only has standby and skyecallerpro and sometimes i have music player but i usually clear it sometimes because when i use the camera or when i edit a video it displays that error.
Yeh had to go for the hard reset, had no applications running in the background. Seems the phone just wasnt freeing up memory when i was deleting stuff. Its a year old now upgrading in a week or so.
Cheers.
😃 😃 😃 😃 yeeeah... 😃 i had the same problem too... well.. i guess that the same... i always used to run out of memory in my headset. 1.i guess, that you have installed n73me software into your n73. 2.check c:/data/lifeblog/database/lifeblog.db... doesn't it weight too much?
check it.....
