I take these softwares in the site of Nokia Open Source, and avery time e try to install it I recieve a message "Certifyd Expired". See attachments!
Now I ask: How? These softwares are open source, freeware... I supose it dont have certifyd.
How can I make it works?
Thanks for any help!
PS. Sorry for my english, and my Symbian is in Portuguese.
have u done on e61 settings to allow all certificate installations instead of just signed only.
1. Go to main menu
2. then go to Tools
3. then go to App. Mgr
4. select Options
5. then go to settings
on software installation select all not signed only.
Thanks SmallBoy, but I set it before. Take look in screeenshot (todo is all in portuguese), I need another solution.
Hi SmallBoy, I fix it! Anoyher friend told me to change date on my phone. I change it to 01/01/2007 and install sucesfull, now I set the real date and still works.
Where do you find these programs? I have an e70 and would LOVE shoutcast/internet radio on my cell phone.
Can this run in the background while you are at the standby screen or must you be within your internet browser whenever you wish to listen to this?
Thanks for the help.
jeremyhelling wrote:Where do you find these programs? I have an e70 and would LOVE shoutcast/internet radio on my cell phone. Can this run in the background while you are at the standby screen or must you be within your internet browser whenever you wish to listen to this?
Try this one. It runs on background also.
http://www.spodtronic.com/en/index.html
It looks as if the certificate has expiered. Set your phones time back a year and try again.
Martin
ratza wrote:Try this one. It runs on background also.
Thanks, I'll give it a try.
A little off topic but has anyone heard how the internet radio bill turned out?
Www.nokia.com/betalabs is one place you can try for shoutcast stuff
Workaround for certificate expired message. Just set your date back a year and it will install.
