Hi Monica or anyone can you help me ? As all this signing business is doing my head in. I have just got Route66.Mobile7.3.520.s60.3rd. OS9 cracked and Route66.v7.3.486.N95 unsigned. I can install the cracked version but I get the message Resource files are missing Please reinstall application. The other version will not install because of the certificate. I have removed all the other countries apart from the UK and left it in the map folder so I could fit it on my memory card as I already have TomTom and Copilot on the card. my ime on my N95 is 352255016335097. Look forward to hearing from you . Heeeeeeeeeeeeeeeeeeeeeeeeeeeeeelp pleaaaaaaaaaaaase Steve
N95 Install route66
sorry this forums does not support crack apps.
but the error would be due to not having maps installed
Plus, never give your IMEI number to anyone!
They can be cloned!
with BB5 it cannot really be cloned as its chip based which means you cannot change IMEI (illegal) without changing the chip.
but dont give out your IMEI as Pa49 said above
Ronaldo-9 wrote:with BB5 it cannot really be cloned as its chip based which means you cannot change IMEI (illegal) without changing the chip.but dont give out your IMEI as Pa49 said above
That's true but can't the number be used in another model that can be rewritten? Makes a stolen phone legit?
maybe, i aint 100% but different manufacturers use different strings at the begining or end and they must match but dont quote me.
