I got my new E90 but the Data Mover is not working
4 replies · 3,902 views · Started 17 July 2007
I'm new to this forum and I like it. I found it when I was looking for support for this phone.
I have a question:
I'm trying to use the Data Mover but the version I found from Nokia.com is the phone is telling my it is not compatible. Is there anyway to fix this. The problem is that my internet I can't set it up as well..
Appreciate your help..
all,
I solved the problem myself after setting up the net. I connected to Nokia website and downloaded automatically and it worked very well..
what do you mean "setup the net" ?
I also have my old m600i and just got my E90...
can't move my contacts.... 😞
iSync is also not working.. !!!
ed
I had the same issue. I was trying to transfer data from my old N70 to the E90.
Gave up, and used Outlook to sync the contacts into the E90 instead.
data mover application: if it says certificate error, just set the old phone date back a couple of years.
isync: works but you need to install the isync plugin for the e90 from nokia's site europe.nokia.com/A4299040
