orange n95 should i update firmware or not
2 replies · 4,502 views · Started 17 July 2007
hi all i'm on orange n95 its a do or don't scenario.
the phone works fine although my mrs has crash a couple of time in the past couple of days.
should i hold off to see what orange are going to do or update both phones with the nokia firmware if i do what differences should we expect?
Hi, I'm on Orange too but have debranded and upgraded the firmware - let me tell you pros outweigh the cons - just read the threads on this site and they'll guide you through it.
The newest firmware holds few problems and the added bonuses of VOIP etc are a boost.
My advice is, if you're confident - go for it!
The downside is if you�re using Oranges 2nd phone line, you will loose it after debranding and if not then you have nothing to loose!
