WebCam on N95 without bluetooth
4 replies · 12,633 views · Started 17 July 2007
Can you clarify which you want? In the title you say without bluetooth and in the body you say with.
If it is the latter, I recommend http://motvik.com/ which is freeware. I don't know about without bluetooth, presumably a USB option is required.
[QUOTE=3Shirts;326885]Can you clarify which you want? In the title you say without bluetooth and in the body you say with.
LOL...Sorry my bad:embarasse
Ment to say without, i'll try again
"Is it possible to use N95 as webcam without using bluetooth"
