Please Share that which 3rd party applications you using and which Applications Working With E90!
I just Install Smart Movie 3.41 and it is working fine.
Seem that almost all (only one or another) don�t work with E90. The main advantage of E90 with S60v3 version is a global compatibility with existing software.
nj7 wrote:Seem that almost all (only one or another) don�t work with E90. The main advantage of E90 with S60v3 version is a global compatibility with existing software.
If only we would have a working version of Fring... But it should be coming soon hopefully.
qreader works
pdf+ works
I just can't install the three free file explorers listed here though...
Hellp people.....i use more than 50 application on my N73...this mean if i upgrade to E90 i dont lose more than 5...
i use almost Epocware applications and mobisystems applications (Handy Safe,Handy Expense,Handy......).
and most important...what about Xplore from LCG?
i have frng working superbly on my E90, have done for about a month or 2.
I have:
Nimbuzz for IM which is working flawlessly
Symtorrent (working quite well)
Gmail (from google not built in Email) and it just doesnt have the layout of buttons correct for the inner screen but otherwise working fine)
I used Slick for IM (which worked exceptionally well and connected very fast but i believe it crashed my phone once or twice as now that its deleted my e90 hasnt crashed yet)
Are they free??
Everything that I listed above is free.
Link to a bunch of freeapps:
http://www.megamobilecontent.com/freeware/Nokia-E90/
Cheers!
U r talking about application work on "one of " the screens of the E90 or both of them?...
when i work on the internal screen i cant go back to the 2' inch one to use it only for "on the move" usage...
Just someone answer me please...does the LCG Xplore file browser work on the internal screen (i know it runs on the external one)...?
