This is only my second theme, so please help me test it. Hopefully there aren't too many bugs. I labeled it beta, just to make sure.
Am I missing something? The only vaguely OS X element of that is the background. None of the icons have changed and the Battery and Signal bars look nothing like the OS X bars!
Yes, you are not missing anything. It's meant to be simple.
I don't want to mock your hard work as it does look nice but I kinda agree with what Indie is saying.
On the face of it, it just looks like a wallpaper taken from Tiger. I think to be able to say its a leopard theme you'd need OSX style icons and some Aqua style colours.
Keep up the good work!
I'm still deciding about the icons, but there certainly are some aqua elements in it. The scrollbar and the process bar when you install things, furthermore the notepad is yellowishly colored, just like the notes in Mac OS.
Not that I don't agree with what you are saying....so you think all think I should change the icons?
If you could get the brushed metal look of Aqua then we'd definately be on our way! 😊
...but yeah, I think wallpaper aside if there were OSX style icons then it would really look like OSX
I've got all the Leopard icons if you want them?
Ok send them to my email. It is my nickname at gmail.
Will do tonight.
Thx. I'll try to include them into the theme, although I think it will get to messy to use with all this shiny icons.
