Some movie trailers for your E90
3 replies · 5,062 views · Started 18 July 2007
Hi guys. I've encoded some movie trailers for the E90 which you're welcome to download and try out.
I'm not allowed to post links so you're going to have to do some cutting and pasting I'm afraid. Put http-colon-slash-slash in front of these links.
homepage.mac.com.nyud.net:8080/mwongozi/things/e90movies/BourneIdentity.zip
Bourne Identity (36.4 MB)
homepage.mac.com.nyud.net:8080/mwongozi/things/e90movies/GoldenCompass.zip
The Golden Compass (32.7 MB)
homepage.mac.com.nyud.net:8080/mwongozi/things/e90movies/Ratatouille.zip
Ratatouille (23.6 MB)
These were all encoded from HD sources from Apple Trailers using VisualHub.
They are designed to play full-screen on the E90 internal screen, so don't forget to hit "Pause" and then "Continue in Full Screen".
Thanks! Great full screen videos (on the full E90 screen, really 😊.
Full screen shortcut is 2 in realplayer, no need to press pause 😉
Mwongozi, would you have any recommendation/advice for me:
- I would like to encode the full Lord of rings trilogy (extended version) to the E90 internal screen format. I am planning to get a 4G microSD card, I think it should fit in, but I haven't spent enough time to research what are my options in term of DVD ripping and re-encoding to E90 format.
Is the 25$ smartmovie app, the best option or can I manage with free alternative like visualhub or other media encoders?
Thanks in advance.
Well VisualHub isn't free, but it is by far the best option for encoding videos for your E90 or for anything else. I recommend it.
Can anybody post their settings for the Handbrake preset then?
Mwongozi wrote:Hi guys. I've encoded some movie trailers for the E90 which you're welcome to download and try out.
