i am up and running with route 66 on my n95 using the internal gprs but I cant seem to find addresses with a 7 digit postcode is their an upgrade like with tomtom or am I just doing something wrong
route 66 postcode
Route 66 for the n95 does not support full postcode search only 4 digit
ok thanks i was hopping someone was not going to say that i guess i will just have to make do then untill tomtom comes out thanks for the info anyway
Are you sure?
It does on my phone (6110), Im aware it might be a different version but unless your using an old one, you should be able to search for a 7 digit postcode like I can.
bartmanekul wrote:Are you sure?It does on my phone (6110), Im aware it might be a different version but unless your using an old one, you should be able to search for a 7 digit postcode like I can.
The latest Britain Map (mid 2006) is 250Mb and crashes on all but the latest 7.3.520 version of Route66. Unfortunately v520 of R66 does not support the N95 Internal GPS.
The N95 compatible version of R66 only works properly with the older 150Mb/4-digit postcode version of the Britain map.
