Is there any apps out there that allows the n95 or symbian handsets to join corporote lans...
I require HTTP Proxy Authentication to access the net at work...but I cant seem to find anyway of doing this...
Windows Mobile comes with an option to enter the
name
password
domain
but I cant find anything for symbian
Tested and Working on N95
rapidshare.com/files/43975879/telexy.networks.symsmb.v2.0.s60v3.unsigned.cracked-binpda.signed.sis.html
Man... is this website turning into a Warez site or what???
winker wrote:Is there any apps out there that allows the n95 or symbian handsets to join corporote lans...I require HTTP Proxy Authentication to access the net at work...but I cant seem to find anyway of doing this...
name
password
domain
Go settings/Access points/yournetwork/options/advanced settings
Pop in your proxy!
Thanks for reply,,,,but that only works if the proxy doesnt require authentication...
ours doess
winker wrote:Thanks for reply,,,,but that only works if the proxy doesnt require authentication...ours doess
Mmmm!
Always thought the authentication box came up when you attempt to connect!
Oh, well learnt some thing there then!
Could I use this to access and play music from my PC over WIFI?
I think Orb is what u are looking for, Im going to test it out tonight....
