Revert to older firmware
2 replies · 2,847 views · Started 20 July 2007
I have an N95 with the O2 network and have upgraded to v11 firmware
Is there anyway to put the old version of firmware (v10) back onto the phone as I may need to send it back to O2. If so where would I find the older versions of the firmware to download.
Thanks in advance.
you cannot downgrade but dont worry, as long as you didnt change product code it wont be a problem. just return it as it is
