i have used the transfer wizard from N95 and now my p910 has got something call datamovie.sis (or somethign similar like that) and i can not open it basically, it says error.
So how can i get the contacts to N95? now i have to carry two phone when i go out, it's so troublesome...pls help!
get yer 910i to sync with outlook , then outlook will sync with n95
is there other way? cause i can't seem to sync my p910 with outlook....sorry for being such a noob
or copy to SIM card and back to the N95
bodstrup wrote:or copy to SIM card and back to the N95
p910 only allows single copy to sim, if i copy my whole contact list to sim, it will take forever....
say u went to contacts on 910 is there a option called "mark" / "Mark All" somet like that , then once you have selected all "copy by bluetooth" then say n95, done this with other fones.
cah1982 wrote:say u went to contacts on 910 is there a option called "mark" / "Mark All" somet like that , then once you have selected all "copy by bluetooth" then say n95, done this with other fones.
yeh tried tht, it only copied like 2 of the contacts...
