Hi Guys do you know any programs other than skye tones that can make video ring tunesplay when someone rings, a the moment i use this app but i want to individualise each callers video/tone like the samsung d600 does....thank you
Video Ring Tune
Any One??
I thought you could just set a video as ringtone.... maybe not... ?
I was sure Id seen it... will have a look.
oooh thank you i was loosing hope sky tones crashes a lot an some times disconnects my calls, my missis phone can do individual videos for individual cal but our "next gen" phone cant , i told her ill get the program but skyephon was not what i had in mind (no offence to the coder)
yeah, Ive had a look.
If you have a caller group, and then add that member to the group... you can set the ringing tone to be the vid... BUT, you only get the audio of the vid... not the vid itself.
Newer versions of firmware in the N80 seem to support playback of the audio of a video clip as a ringtone. Unfortunately, this is only the audio and not the actual video itself.
SkyeTones, which I used to use seems to work fine for me. You can set a video ringtone for a contact or a profile. If you are wanting to set a video ringtone to a given contact, then SkyeTones does support that.
I have since upgraded to SkyeCaller PRO. This newer app from Skyestream includes all the same funtionality as SkyeTones (ie video ringtones), but also has full-screen caller functionality. Anyway, SkyeCaller PRO seems pretty solid and video ringtones work fine for me on my N80 with this software...
template60 wrote:Newer versions of firmware in the N80 seem to support playback of the audio of a video clip as a ringtone. Unfortunately, this is only the audio and not the actual video itself.SkyeTones, which I used to use seems to work fine for me. You can set a video ringtone for a contact or a profile. If you are wanting to set a video ringtone to a given contact, then SkyeTones does support that.
WORD UP (OWWW EVERY BODIE SING)
CHEERS MATE WILL HAVE TO LOOK OUT FOR DAT ONE
