73 Music Edition Firmware.
New features:
- FOTA (Flashing Over The Air)
- Bluetooth Stereo
- A2DP Support
- Dial-up over IR
- Lifetimer Reset for reflashed phones
- Vibra Boot notification
- Configurable Flash setting function for Camera
- Secure Formatter with TCB and All-Files capabilities
- N Series Music Player replaces S60 Music Player
- Online Album included
- Active Standby + UI Grid layout + application locations changed in-line
with Pre-Space UI layout.
Removed features:
- Snakes
Improvements:
- Weather Deck wording alignement
- Spurious �Out of Memory� indications
- Icons and text in Application Shell
- Icon in �Catalogs�
- Folder validity updates
- Alarm clock function, when handset is turned off
- Active Standby Shortcut 6 function
- Quick Office �Save� options
- Bluetooth search �Searching for Devices�
- Camera can not be launched if RAM is low.
- Music player - Indicator appears on the idle state background, after
saving a music track
- Phone reboots if wrong memory card password is entered
- Memory card details are not read correctly if the card is locked by DUV
- Tutorial � Occasional malfunction
- Music player starts when BT stereo headset is switched OFF
- Unable to create FOTA Server profile
- "System Error" occurs when trying to synchronize after restoring the
backed up info.
- "App. Closed: Device manager" is detected after exiting from New
server profile view.
- Gallery crashes or phone reboots when moving rocker after making a
new album in gallery
- Long name for messaging settings makes messaging unusable
- Online Print improvement.
- Streaming improment for H3G
Source: Nokia Europe Support Discussion forums.
By: Shayesta
Any idea on affected Product codes ? I tried searching Nokia for the Euro 1 ME number (0537289) and it still lists 3.0705.
lovesign wrote:Any idea on affected Product codes ? I tried searching Nokia for the Euro 1 ME number (0537289) and it still lists 3.0705.
i have 04.07.727.2.2.1 euro 1 0537289 just remove the software update from nokia reboot your pc then intall it again,change the phone tothat product code and then star nokia software update,works all the time
eduarte wrote:i have 04.07.727.2.2.1 euro 1 0537289 just remove the software update from nokia reboot your pc then intall it again,change the phone tothat product code and then star nokia software update,works all the time
Way ahead of ya, but thanks anyway 😉
ive tried everything but i cant change my productcode, im in sweden and thought i would be able to get the latest version byt that was not the case so i dl the NSS app and tried that but it only comes up with this crap:
Checking Framework...Done.
->..pdginterfc.dll version: 1.0.479
->....pdg4fbus.dll version: 1.0.1641
->....pdg4mbus.dll version: 1.0.106
->.....pdg4fls.dll version: 1.0.1164
->....pdg4flsc.dll version: 1.0.0.58
->pdgphonebook.dll version: 1.0.189
->.bb5usbflash.dll version: 1.0.0.42
Reading Virtual USB device...Done.
->Serial: 2E8B99D1, HW: 0.0
Testing Interfaces...
->USB DKU2....Supported.
->USB CA-53...Supported.
Testing Directories...
->DCT4 Loaders Dir('Flash'😉......Found.
-->0 file(s) found.
-->Please copy the loaders first!
->ADSP Loaders Dir('FlashUsb'😉...Found.
-->0 file(s) found.
->DCT3 Loaders Dir('fls1sup'😉....Found.
-->0 file(s) found.
->Products Dir('products'😉.......Not Found.
Open Diamond...Error!
and when i try to read the phones info i only get reading values... error
my fw is v3.0638.0.0.30 rm-133 nokia n73 (Y3.02)
i really would be happy if someone could help me out here?
by the way thanks for an awsome forum just regged today but been keeping my eye on it for a long time.
Ps: sorry for my bad english
why is it impossible for you to change the product code? and what is your current product code?
This works for me :-
Start up PC Suite.
Connect phone to usb. (Select 'PC Suite'😉
Minimize PC Suite.
Start NSS.
Click on 'Scan for new devices'.
Click on 'Phone info'.
Click on 'Scan'.
You can then click on 'read' to find your present product code.
Put a tick in the 'enable' box opposite 'product code'
Enter your new producr code & click 'write'.
It only takes 2 seconds & its done.
Hope this helps. 😊
i got it to work awsome to damn bad i didnt get the swedish language any help on that would be awsome, well i did get it to work after all with swedish language.
Interesting, now that I'm on this v4 firmware, I've started to get spurious "Out of memory" errors ... NEVER had them before 😡
Getting kernelexec errors .... and various other subsystem crashes, but it keeps on working.
But I'm mulling over getting a 4 gig card, as I've read of a few people having success, and moby are listing their 4gig card as compatible.
Hey,
Thanks for informing us with the release of new Firmware version..
I've updated my phone's firmaware but the lifetimre still shows the old reading.. how do I reset that !?
Hi there,
I've got the same problem like you.. have u come up with a solution? if i do will let u know. Please let me know. Cause my doing exactly the same thing!! pfft!!!
atiksha
hampad wrote:ive tried everything but i cant change my productcode, im in sweden and thought i would be able to get the latest version byt that was not the case so i dl the NSS app and tried that but it only comes up with this crap:Checking Framework...Done.
-->0 file(s) found.
-->0 file(s) found.
-->0 file(s) found.
well i need to re flash my phone but i have no idea on how to do it.
i tried uninstall the update app and rebooted my pc no luck, i tried diffrent product codes on the phone with no luck. don�t know what to do.
i need to do this because my phone is acting up cant uninstall apps install apps and stuff like that. please help
Guys I don't know if this is old or not but you can exit the MENU by going thru Options Exit. but when accessing it back it takes like 3 secs or 4.
On Best Taskman (3rd party app) I got STANDYBY mode only, in the running application.
