Tried to Sync my N73 but it showed the following warning.
It used to work fine but its showing this since yesterday
Error as follows:
The mobile phone has not responded.
PC Sync has encountered a problem and has terminated the synchronisation.
Possible Solution
Please check your Synchronisation settings and ensure your phone is in the Idle state, then restart the Synchronisation
Plz Help ....
Hi vickyrathod
Tell the exact step which u r doing for syncing ur Phone to PC or Laptop.
And be sure that no antivrus security is stopping it.
try to do it in the following way:
As soon as you plug the usb cable into the computer and onto the phone, the N73 gives us a menu to select what we are trying to do with the phone. Select PC Suite if you want to connect to nokia PC suite or select mass storage.
In the case of "data Transfer Mode" the memory card in the phone will appear as a regular drive and you can copy files back and fo. If you don't do either of these, nothing will happen and no drivers will be found.
Hope u r able to sync it properly.
yes ofcourse i selected PC Suite i can transfer images, music etc but when i tried to sync is giving an error which i mentioned earlier.
Even when i tried to update my contacts it showed the same error.
It was working fine last week but the problem started since saturday.
I donno whatz creating this problem.
