Connection to the storange medium has been interrupted. Attach your storage medium an
3 replies · 2,165 views · Started 23 July 2007
I have searched the forums and been googleling but cant seem to be able to find the correct answer.
How do i find a solution for the Nokia Map Loader error?
When I connect my n95 to pc and choose data transefer/ data storage whatever its called, and I start the program and it begins to download the map and then it says Connection to the storange medium has been interrupted. Attach your storage medium and retry.
Got v.12...13 firmware in my phone, and nothing is wrong with my connection to internet/computer- phone. Still i get the error.
What do i do?
Really appreciate help.
common anyone? you guys are pros and am sure am not the only one discoverds this bug?
no idea of what is wrong?
This is what it looks like
hxxp://img466.imageshack.us/img466/261/afasuk1.jpg
remove the xx to tt
I would try another cable to check if problem is with the actual cable make sure connections are tight ,if not put maps directly onto card via a card reader and see if that works,
godamn crap worked with my other computer.
probably something aint right with the nokia apps i got installed.
