hello.........
does anybody here knows how to close running application?
or does it close automatically?
anyone knows how to clear the sim last dialed?
hello.........
I'm just saying this from knoledge i got browsing this forum
I dont own a p800.
It seems that Symbian 7 UIQ does not close apps by default,it leaves them runing in the background so your device might get slow after a while.
You have to exit the app manualy,try searching apps menus or such.
Filemanager can close programs - i use it all the time 😉 Most programs are unfortunatly not closed ;-(
best
Kasper
Yes you are right,i forgot about that,apps can be closed with qfileman 😃
ic..
thanks..
do u happen to know how to clear the "sim last dialed?
