I have just updated my firmware on my N73 and want to restore my backup contacts.
However my old laptop just keeps blues screening, so i want to transfer the backup file to my PC and restore it from there.....The problem is that I cannot find the file.
What is the file extension so I can do a search, does it sve it in a default file...??
Unless specified otherwise by the user, it usually resides in C:\Documents and Settings\xxxx\Application Data\Nokia\ContentCopier\
...where xxxx = the name of your "My Documents" folder.
The file automatically names itself with the date i.e. 2007-07-23 Nokia N73
Hope that helps,
Rob.
You are a star, thanks alot....At first I could not find it due to having "Hidden Files" turned off... Now all backed up and happy...:tongue:
