Where are the Java MIDlets?
1 replies · 1,742 views · Started 23 July 2007
Can someone tell me where the Java MIDlets are stored on the N95? On my 6600 and N70, they were saved in the /system/MIDlets/ folder (either C or E, depending on whether I saved them on the phone's memory or the memory card).
I've looked for this folder on the N95 (using Y-Browser) but have had no luck. Can anyone help?
They're somewhere under \private in phone memory or the memory card, but you can't get there using Y-Browser or any file manager running on the phone (that does not have the, so called, AllFiles privilege/capability).
If you install a MIDlet on the memory card, and connect the phone with the USB cable in USB mass storage mode & make sure you can view hidden&system files on your PC, then you can locate the directory where the .jar files are under \private.
