Nokia n95 and Canon Video IP Security Cameras
3 replies · 9,397 views · Started 23 July 2007
Hi all, just wondering if anyone has got there n95 to view security IP camera video feeds ?
We use canon IP security cameras which have a IP address assigned to them, and the camera has a java applet which you normally use for viewing on a computer web brosnwer.... When you load up the page on the n95 web program and navigate to the IP camera it logs in fine, but doesn�t display the Java live video stream any suggestions ?
the typical path to the video is something like this
192.168.1.153/top/liveapplet.html
The camera also has its own viewing software which is called webview-TCP wv-tcp from which I can get the following information
Video [wv-tcp] 192.168.1.153:65310
Camera control 192.168.1.153:65311
b/w the camera im trying to make work is a Canon VB-C50Fsi
Regards James
Just tired mini opera 4.0 beta and it still wont load.. iv also tried loading a java ftp client program also.. which I can't get to load...(just as a test)
Can someone with a n95 see if they can access the ftp client applet as a test on there n95 browser http---- (www)(DOT)radinks.net/ftp/applet/demo.php
If I can make this applet work im sure the internal security camera one will work also..
Regards James
The N95 supports only J2ME (Java 2 Micro Edition) and cannot run J2SE (Java 2 Standard Edition) applets like what a PC can.
